The following is an illustration of the 8-socket chassis, midplane, and shuttle:
Item no | Description | Replacement Part number | CRU/FRU |
1 | Shuttle |
4U (included in part number 95Y4386) | | |
2 | ServeRAID |
M5210 SAS/SATA Controller | 46C9111 | |
M5120 SAS/SATA Controller | 00AE811 | |
3 | Board |
Storage I/O book | 00D0055 | |
4 | Filler |
compute book (all models) | 95Y4378 | |
5 | Compute book |
IBM X6 DDR3 | 00D0050 | |
6 | Fan |
Front Hot-Swap | 95Y4376 | |
7 | Storage book |
IBM X6 (with power cable, rear air duct, and supercap or flash power module brackets) | 95Y4380 | |
8 | Front I/O panel |
(USB or video and front air duct) | 95Y4382 | |
9 | Hard Drive |
900 GB 10 000 rpm 2.5-inch SAS Gen3 Hot-Swap hard drive | 00AJ072 | |
300 GB 15 000 rpm 2.5-inch SAS Gen3 Hot-Swap hard drive | 00AJ082 | |
1 TB 7 200 rpm 2.5-inch SAS Gen3 NL Hot-Swap hard drive | 00AJ087 | |
600 GB 10 000 rpm 2.5-inch SAS Gen3 Hot-Swap hard drive | 00AJ092 | |
300 GB 10 000 rpm 2.5-inch SAS Gen3 Hot-Swap hard drive | 00AJ097 | |
146 GB 15 000 rpm 2.5-inch SAS Gen3 Hot-Swap hard drive | 00AJ112 | |
500 GB 7 200 rpm 2.5-inch SAS Gen3 NL Hot-Swap hard drive | 00AJ122 | |
250 GB 7 200 rpm 2.5-inch SAS Gen3 NL Hot-Swap hard drive | 00AJ132 | |
500 GB 7 200 rpm 2.5-inch SAS Gen3 NL Hot-Swap hard drive | 00AJ137 | |
1 TB 7 200 rpm 2.5-inch SATA Gen3 NL Hot-Swap hard drive | 00AJ142 | |
1.2 TB 10 000 rpm 2.5-inch SAS Gen3 Hot-Swap hard drive | 00AJ147 | |
| Self-encrypting drive (SED) |
900 GB 10 000 rpm 2.5-inch, SAS Gen3 Hot-Swap hard drive | 00AJ077 | |
600 GB 10 000 rpm 2.5-inch SAS Gen3 Hot-Swap hard drive | 00AJ102 | |
300 GB 10 000 rpm 2.5-inch SAS Gen3 Hot-Swap hard drive | 00AJ107 | |
146 GB 15 000 rpm 2.5-inch, SAS Gen3 Hot-Swap hard drive | 00AJ117 | |
1.2 TB 10 000 rpm 2.5-inch, SAS Gen3 Hot-Swap hard drive | 00AJ152 | |
| Solid state drive |
200 GB S3700 Enterprise 2.5-inch SATA Gen3 MLC Hot-Swap hard drive for IBM System x | 00AJ157 | |
400 GB S3700 Enterprise 2.5-inch, SATA Gen3 MLC Hot-Swap hard drive for IBM System x | 00AJ162 | |
800 GB S3700 Enterprise 2.5-inch, SATA Gen3 MLC Hot-Swap hard drive for IBM System x | 00AJ167 | |
| Solid state drive |
200 GB 2.5-inch SAS Gen3 MLC Enterprise Hot-Swap hard drive | 00AJ208 | |
400 GB 2.5-inch SAS Gen3 MLC Enterprise Hot-Swap hard drive | 00AJ213 | |
800 GB 2.5-inch SAS Gen3 MLC Enterprise Hot-Swap hard drive | 00AJ218 | |
1.6 TB 2.5-inch SAS Gen3 MLC Enterprise Hot-Swap hard drive | 00AJ223 | |
120 GB 2.5-inch SATA Gen3 MLC Enterprise Hot-Swap hard drive (for x3950 X6 8U) | 00AJ396 | |
240 GB 2.5-inch SATA Gen3 MLC Enterprise Hot-Swap hard drive (for x3950 X6 8U) | 00AJ401 | |
480 GB 2.5-inch SATA Gen3 MLC Enterprise Hot-Swap hard drive (for x3950 X6 8U) | 00AJ406 | |
800 GB 2.5-inch SATA Gen3 MLC Enterprise Hot-sSwap hard drive (for x3950 X6 8U) | 00AJ411 | |
800 GB 1.8-inch SATA MLC S3500 Enterprise SSD for IBM System x (for x3950 X6 8U) | 00AJ456 | |
| Solid state drive |
200 GB 1.8-inch SATA Gen3 MLC Hot-Swap S3700 Enterprise for IBM System x | 41Y8367 | |
400 GB 1.8-inch SATA Gen3 MLC Hot-Swap S3700 Enterprise for IBM System x | 41Y8372 | |
120 GB 1.8-inch SATA MLC Enterprise (for x3950 X6 8U) | 00AJ336 | |
240 GB 1.8-inch SATA MLC Enterprise (for x3950 X6 8U) | 00AJ341 | |
480 GB 1.8-inch SATA MLC Enterprise (for x3950 X6 8U) | 00AJ346 | |
800 GB 1.8-inch SATA MLC Enterprise (for x3950 X6 8U) | 00AJ351 | |
10 | Drive filler |
2.5-inch hard disk (included in part number 95Y4383) | | |
11 | Backplane |
4x 2.5-inch Hot-Swap 12 Gb SAS/SATA HDD or SSD | 00JY036 | |
4x2.5-inch Hot-Swap NVMe PCIe SSD | 44X4108 | |
12 | Backplane |
8x 1.8-inch Hot-Swap 12 Gb SAS/SATA HDD or SSD | 47C9941 | |
| 8x2.5-inch Hot-Swap 12 Gb SAS HDD | 44X4112 | |
13 | Backplane filler |
8x1.8-inch drive (included in part number 95Y4383) | | |
14 | Chassis and shuttle |
4U assembly | 95Y4386 | |
15 | Midplane |
4U chassis | 00D0051 | |
16 | Fan |
Rear Hot-swap | 95Y4377 | |
17 | I/O book |
IBM X6 Standard (with fan cable and air duct) | 00FN707 | |
18 | IBM X6 Half-Length (models A4X, H1X) | 00D0053 | |
19 | IBM X6 Full-Length (with brackets and two supplemental power cables) | 00D0054 | |
20 | I/O book |
filler (all models) | 95Y4379 | |
21 | Power supply |
Power supply spacer (for 900W and 750W power supplies) (included in part number 95Y4383) | | |
22 | Power supply |
900 Watt Emerson | 94Y8118 | |
900 Watt Delta | 94Y8120 | |
23 | Power supply |
filler (included in part number 95Y4383) | | |
24 | Power supply | | |
1400 Watt Emerson (This part is interchangeable with part number 69Y5956) | 69Y5954 | |
1400 Watt Delta (This part is interchangeable with part number 69Y5954) | 69Y5956 | |
| Power Supply |
750 Watt DC | 69Y5742 | |
25, 26, 27 | Upgrade kit |
x3950 4-socket to 8-socket (include 8-socket chassis, 8-socket midplane, and 8-socket shuttle) - 8U | 44X4058 | |
| Air baffle and ducts kt |
(all models) | 95Y4385 | |
| Cable |
Internal SAS | 00FN501 | |
Auxiliary | 00FN567 | |
ront operator panel (included in part number 00D0333) | | |
Management arm kit | 95Y4390 | |
| Chassis handles kit |
(all models) | 95Y4384 | |
| EIA trim bezel kit |
(all models) | 95Y4391 | |
| Filler kit |
(all models) | 95Y4383 | |
| Front operator panel |
(include bracket, lightpipe assembly)(all models) | 00D0333 | |
| Handles |
cam (front) (all models) | 00FN594 | |
cam (rear) (all models) | 00FN595 | |
| Labels |
4U (all models) | 00FN503 | |
| LCD display panel |
(all models) | 00D0464 | |
| Memory |
4 GB ( Single-Rank x4) 1.35 V PC3-12800 DDR3 ECC 1600 MHz LP RDIMM | 00D5026 | |
8 GB (Single-Rank x4) l.35 V PC3-12800 DDR3 ECC 1600 MHz LP RDIMM | 00D5038 | |
16 GB (Dual-Rank x4) 1.35 V PC3-12800 DDR3 ECC 1600 MHz LP RDIMM | 46W0674 | |
32 GB (Quad-Rank x4) 1.35 V PC3-12800 DDR3 ECC 1600 MHz LP LR-DIMM | 46W0678 | |
64 GB (Eight-Rank x4) 1.35 V PC3-10600 DDR3 ECC 1333 MHz LP LR-DIMM | 46W0743 | |
| Storage DIMM |
eXFlash 200 GB DDR3 | 00FE001 | |
eXFlash 400 GB DDR3 | 00FE006 | |
| Microprocessor and heatsink |
(all models) | 95Y4388 | |
| Microprocessor |
Six-Core E7-4809 v2 1.9 GHz (12 MB cache) 105 W | 44X3963 | |
Eight-Core E7-4820 v2 2.0 GHz (16 MB cache) 105 W | 44X3968 | |
Ten-Core E7-4830 v2 2.2 GHz (20 MB cache) 105 W | 44X3973 | |
Twelve-Core E7-4850 v2 2.3 GHz (24 MB cache) 105 W | 44X3978 | |
Twelve-Core E7-4860 v2 2.6 GHz (30 MB cache) 130 W | 44X3983 | |
Fifteen-Core E7-4870 v2 2.3 GHz (30 MB cache) 130 W | 44X3988 | |
Fifteen-Core E7-4880 v2 2.5 GHz (37.5 MB cache) 130 W | 44X3993 | |
Fifteen-Core E7-4890 v2 2.8 GHz (37.5 MB cache) 155 W | 44X3998 | |
Twelve-Core E7-8850 v2 2.3 GHz (24 MB cache) 105 W | 44X4003 | |
Twelve-Core E7-8857 v2 3.0 GHz (30 MB cache) 130 W | 44X4033 | |
Fifteen-Core E7-8870 v2 2.3 GHz (30 MB cache) 130 W | 44X4013 | |
Fifteen-Core E7-8880 v2 2.5 GHz (37.5 MB cache) 130 W | 44X4018 | |
Fifteen-Core E7-8880L v2 2.2 GHz (37.5 MB cache) 105 W | 44X4038 | |
Fifteen-Core E7-8890 v2 2.8 GHz (37.5 MB cache) 155 W | 44X4023 | |
Ten-Core E7-8891 v2 3.2 GHz (37.5 MB cache) 155 W | 44X4028 | |
Six-Core E7-8893 v2 3.4 GHz (37.5 MB cache) 155 W | 44X4008 | |
Eight-Core E7-4809 v3 2.1 GHz (20 MB cache) 115 W | 00ML902 | |
Twelve-Core E7-4830 v3 2.1 GHz (30 MB cache) 115 W | 00ML910 | |
Fourteen-Core E7-4850 v3 2.2 GHz (35 MB cache) 115 W | 00ML914 | |
Twelve-Core E7-4857 v3 2.5 GHz (30 MB cache) 140 W | 00ML918 | |
Ten-Core E7-4820 v3 4.9 GHz (25 MB cache) 115 W | 00ML906 | |
Eighteen-Core 2.0 GHz E7-8880L v3 (45 MB cache) 115 W | 00ML938 | |
Eighteen-Core 2.1 GHz E7-8870 v3 (45 MB cache) 140 W | 00ML926 | |
Sixteen-Core 2.2 GHz E7-8860 v3 (40 MB cache) 140 W | 00ML922 | |
Eighteen-Core 2.3 GHz E7-8880 v3 (45 MB cache) 140 W | 00ML930 | |
Sixteen-Core 2.5 GHz E7-8857 v3 (45 MB cache) 165 W | 00FP692 | |
Eighteen-Core 2.5 GHz E7-8890 v3 (45 MB cache) 165 W | 00ML934 | |
Ten-Core 2.8 GHz E7-8891 v3 (45 MB cache) 165 W | 00ML942 | |
Quad-Core 3.2 GHz E7-8893 v3 (45 MB cache) 140 W | 00ML946 | |
| Microprocessor installation tool |
(for E7-x8xx v2 series) | 94Y9971 | |
| Midplane |
x3950 X6 8-socket (8U) | 00D0056 | |
| Host Bus Adapter |
N2125 SAS/SATA Host Bus Adapter for IBM System x | 46C9011 | |
N2215 SAS/SATA Host Bus Adapter for IBM System x | 47C8676 | |
| PCI Express x16 Adapter |
Intel Xeon Phi 3120A | 90Y2403 | |
NVIDIA Grid K1 | 90Y2355 | |
NVIDIA Grid K2 Actively Cooled | 90Y2395 | |
NVIDIA Quadro K4000 | 90Y2375 | |
NVIDIA Quadro K6000 | 90Y2371 | |
NVIDIA Tesla K20 Actively Cooled | 90Y2391 | |
NVIDIA Tesla K40c | 90Y2408 | |
| Ethernet Adapter |
Intel X540 ML2 Quad-Port 1 Gb-T | 47C8210 | |
Intel I350-T4 ML2 Dual-Port 10 Gb-T | 47C8152 | |
Emulex VFA5 ML2 Dual-Port 10 Gb-SFP+ | 47C8153 | |
Broadcom NetXtremeII ML2 Dual-Port 10 Gb-T | 94Y5233 | |
Broadcom NetXtremeII ML2 Dual-Port 10 Gb-SFP+ | 94Y5231 | |
| Rail kit |
(all models) | 88Y6721 | |
This topic provides a list of server consumable parts.
Consumable parts are not covered by the IBM Statement of Limited Warranty. The following consumable parts are available for purchase from the retail store.
