Move the pointer over the part for a description. Click the part to locate the part number.
Item | Description | Replacement part number | CRU |
1 | Top Cover |
(all models) | 81Y7455 | |
2 | PCIe Riser Card |
(all models) | 81Y7457 | |
3 | ServeRAID BR10il v2 Adapter (with bracket) |
(all models) | 49Y4737 | |
4 | Air Baffle |
(all models) | 81Y7453 | |
5 | Memory |
1 GB (Single-Rank) PC3 10600R-999 DDR3 ECC RDIMM (all models) | 44T1572 | |
2 GB (Single-Rank) PC3 12800 CL11 DDR3 ECC UDIMM | 00D4953 | |
2 GB (Single-Rank) PC3 10600R-999 DDR3 ECC RDIMM (all models) | 44T1574 | |
4 GB (Dual-Rank) PC3L 10600 CL9 DDR3 ECC UDIMM | 49Y1422 | |
4 GB (Dual-Rank) PC3 10600R-999 DDR3 ECC RDIMM (all models) | 44T1575 | |
4 GB (Dual-Rank) PC3 12800 CL11 DDR3 ECC UDIMM | 00D4957 | |
8 GB (Dual-Rank) PC3 12800 CL11 DDR3 ECC UDIMM | 00D4961 | |
6 | Power Supply |
300 W Fixed (all models) | 81Y6301 | |
460 W Redundant Hot-Swap (all models) | 39Y7229 | |
300 W fixed (Korea) | 00AL207 | |
7 | Chassis |
(with fixed power supply) (all models) | 81Y7456 | |
(with redundant power supply) (all models) | 90Y5958 | |
8 | Backplane |
2.5-inch Simple-Swap | 81Y7466 | |
2.5-inch SAS Hot-Swap (with redundant power supply) (all models) | 46C6757 | |
9 | Backplate |
3.5-inch Simple-Swap SATA (for 1 cable) | 81Y7465 | |
3.5-inch Simple-Swap SATA (for 2 cables) | 81Y7464 | |
10 | Hard Drive |
2 TB 3.5-inch Simple-Swap SATA (all models) | 42D0788 | |
1 TB 3.5-inch Simple-Swap SATA (all models) | 43W7625 | |
500 GB 3.5-inch Simple-Swap SATA II (all models) | 39M4517 | |
250 GB 3.5-inch Simple-Swap SATA II (all models) | 39M4529 | |
11 | Filler Panel |
3.5-inch Simple-Swap hard drive (model 22x, 32x, and C2x) | 39M4343 | |
12 | Filler Panel |
2.5-inch Simple-Swap hard drive (all models) | 81Y7460 | |
2.5-inch Hot-Swap hard drive (with redundant power supply) | 44T2248 | |
13 | Hard Drive |
128 GB 2.5-inch Simple-Swap SATA | 90Y8649 | |
146 GB 2.5-inch Simple-Swap SAS (all models) | 49Y1997 | |
146 GB 2.5-inch Hot-Swap SAS (with redundant power supply) (all models) | 42D0678 | |
250 GB 2.5-inch Hot-Swap SATA | 81Y9723 | |
256 GB 2.5-inch Simple-Swap SATA | 90Y8644 | |
300 GB 2.5-inch Simple-Swap SAS (all models) | 49Y1992 | |
300 GB 2.5-inch Hot-Swap SAS (with redundant power supply) (all models) | 42D0638 | |
500 GB 2.5-inch Hot-Swap SAS (with redundant power supply) (all models) | 42D0708 | |
500 GB 2.5-inch Hot-Swap SATA | 81Y9727 | |
600 GB 2.5-inch Simple-Swap SAS (all models) | 49Y2028 | |
600 GB 2.5-inch Hot-Swap SAS (with redundant power supply) (all models) | 49Y2004 | |
900 GB 2.5- inch Hot-Swap SATA | 81Y9651 | |
1 TB 2.5-inch Hot-Swap SATA | 81Y9731 | |
14 | Front Bezel |
(all models) | 81Y7458 | |
15 | Operator Information Panel |
(all models) | 90Y5298 | |
16 | Optical Drive |
CD-RW/DVD-RW (all models) | 44W3256 | |
DVD-ROM (all models) | 44W3254 | |
17 | Filler Panel |
DVD drive bay (all models) | 49Y4868 | |
18 | System Fan |
Simple-Swap (all models) | 81Y7454 | |
19 | System Board |
(all models) | 00AL958 | |
20 | Microprocessor |
Single-Core Intel Celeron G440 1.6 GHz (1 MB cache) | 69Y5148 | |
Dual-Core Intel Core i3-2100 3.1 GHz/1333 MHz (3 MB cache) 65 W (all models) | 94Y6303 | |
Dual-Core Intel Core i3 2120 3.3 GHz (3 MB cache) | 99Y1447 | |
Dual-Core Intel Xeon E3-1220L 2.2 GHz/1333 MHz (3 MB cache) 20 W (all models) | 81Y6951 | |
Xeon E3-1220L v2 2.3 GHz (3 MB cache) | 00Y7408 | |
Dual-Core Intel Pentium G850 2.9 GHz (3 MB cache) (all models) | 81Y7504 | |
Dual-Core Intel Pentium G870 3.1 GHz (3 MB cache) (all models) | 00D8899 | |
Dual-Core Intel Pentium G860T 2.6 GHz (3 MB cache) (all models) | 00D8900 | |
Dual-Core Intel Pentium G640 2.8 GHz (3 MB cache) (all models) | 00D8901 | |
Dual-Core Intel Pentium G640T 2.4 GHz (3 MB cache) (all models) | 00D8902 | |
Dual-Core Intel Pentium G550 2.6 GHz (2 MB cache) (all models) | 00D8903 | |
Dual-Core Intel Pentium G540T 2.1 GHz (2 MB cache) (all models) | 00D8904 | |
Quad-Core Intel Xeon E3-1270 3.4 GHz/1333 MHz (8 MB cache) 80 W (all models) | 69Y5149 | |
Dual-Core Intel Core i3-2120 3.3 GHz/1333 MHz (3 MB cache) (65 W) (all models) | 69Y5151 | |
Quad-Core Intel Xeon E3-1240 3.3 GHz/1333 MHz (8 MB cache) 80 W (all models) | 69Y5152 | |
Quad-Core Intel Xeon E3-1280 3.5 GHz/1333 MHz (8 MB cache) 95 W (all models) | 81Y6933 | |
Quad-Core Intel Xeon E3-1220 3.1 GHz/1333 MHz (8 MB cache) 80 W (all models) | 81Y6945 | |
Quad-Core Intel Xeon E3-1230 3.2 GHz/1333 MHz (8 MB cache) 80 W (all models) | 81Y6947 | |
Quad-Core Intel Xeon E3-1260L 2.3 GHz/1333 MHz (8 MB cache) 45 W (all models) | 81Y6949 | |
Quad-Core Intel Xeon E3-1220 v2 3.1 GHz (8 MB cache) (all models) | 00D8552 | |
Quad-Core Intel Xeon E3-1270 v2 3.5 GHz (8 MB cache) (all models) | 00D8553 | |
Quad-Core Intel Xeon E3-1280 v2 3.6 GHz (8 MB cache) (all models) | 00D8554 | |
Quad-Core Intel Xeon E3-1240 v2 3.4 GHz (8 MB cache) (all models) | 00D8555 | |
Quad-Core Intel Xeon E3-1230 v2 3.3 GHz (8 MB cache) (all models) | 00D8556 | |
Quad-Core Intel Xeon E3-1265L v2 2.5 GHz (8 MB cache) (all models) | 00D8557 | |
21 | Heat Sink |
(all model) | 81Y7495 | |
. | Cover |
Safety 240 VA (all model) | 81Y7526 | |
. | Paddle Card |
Power Supply Backplane (all models) | 00D3712 | |
. | Battery |
3.0 V (all models) | 33F8354 | |
. | PCI Riser Card |
(all models) | 81Y7494 | |
. | Adapter |
ServeRAID H1110 SAS/SATA | 81Y4494 | |
. | ServeRAID-M1000 Series Advanced Feature Key |
(all models) | 46M0864 | |
. | Disk Controller |
ServeRAID M1015 SAS/SATA controller | 46M0861 | |
ServeRAID M5014 SAS/SATA controller | 46M0918 | |
. | Cable |
Front USB and operator information panel | 81Y7463 | |
Backplate 3.5-inch Simple-Swap SATA (2 cables) | 81Y7464 | |
Backplate 3.5-inch Simple-Swap SATA (1 cable) | 81Y7465 | |
Backplane 2.5-inch simple-swap SATA | 00D4344 | |
DVD drive | 59Y3229 | |
Backplate 2.5-inch Simple-Swap SAS | 81Y7466 | |
Power supply unit interposer power | 00D8685 | |
| Optical transceiver |
Brocade 10 Gb SFP+ SR (all models) | 42C1819 | |
. | Converged Network Adapter |
Brocade 10 Gb Dual-Port CNA | 42C1822 | |
| QLogic 10 Gb Dual-Port CNA |
(all models) | 42C1802 | |
. | Optical Transceiver |
QLogic 10 Gb SFP+ SR (all models) | 42C1816 | |
. | Filler |
Power Supply (with redundant) (all models) | 49Y4821 | |
. | Hard Drive Cage |
2.5-inch Hot-Swap (with redundant power supply) | 81Y7528 | |
3.5-inch Simple-Swap | 81Y7461 | |
. | Host Bus Adapter |
Emulex 8 Gb Fibre Channel Single-Port | 42D0491 | |
Emulex 8 Gb Fibre Channel Dual-Port | 42D0500 | |
QLogic 8 Gb Fibre Channel Single-Port | 42D0507 | |
QLogic 8 Gb Fibre Channel Dual-Port | 42D0516 | |
. | NetXtreme II 1000 Express Dual-Port Ethernet Adapter |
(all models) | 49Y7947 | |
. | NetXtreme II 1000 Express Ethernet Adapter |
(all models) | 49Y7949 | |
. | NetXtreme 1000 Express Dual-Port Ethernet Adapter |
(all models) | 94Y6263 | |
. | NetXtreme I Quad-Port Adapter |
(all models) | 90Y9355 | |
. | NetXtreme I Dual-Port Adapter |
(all models) | 90Y9373 | |
. | Ethernet Dual-Port Server Adapter I340-T2 |
(all models) | 49Y4232 | |
. | Ethernet Quad-Port Server Adapter I340-T4 |
(all models) | 49Y4242 | |
. | Bracket |
EAR (all models) | 39M4351 | |
. | Miscellaneous Kit |
(all models) | 81Y7459 | |
. | 1U Tool-less Kit |
(all models) | 24P1121 | |
. | Service Label |
(all models) | 81Y7507 | |
(all models) | 00D4340 | |
(all models) | 00D4342 | |
