Question & Answer
Question
When trying to update the requirements in Requirement Tracing (requirements imported from DOORS via Gateway) for all documents, I receive a message 'DOORS conversion Problem'
Cause
One possibility is if the path on the DOORS document in Gateway to the requirement module becomes invalid, Rhapsody Gateway might have lost its location in Doors and such conversion error occurs. This might happen as a result of module name change.
Answer
You can remove the DOORS document in Gateway project configuration window and reapply or Reset the path on it to the requirements module and check the behavior
[{"Line of Business":{"code":"LOB59","label":"Sustainability Software"},"Business Unit":{"code":"BU059","label":"IBM Software w\/o TPS"},"Product":{"code":"SSB2MU","label":"IBM Engineering Systems Design Rhapsody"},"ARM Category":[{"code":"a8m50000000CjZYAA0","label":"Rhapsody-\u003ETools-\u003EGateway"}],"ARM Case Number":"","Platform":[{"code":"PF025","label":"Platform Independent"}],"Version":"All Version(s)"}]
Product Synonym
Rhapsody; Gateway
Was this topic helpful?
Document Information
Modified date:
21 July 2023
UID
ibm16328081
