Troubleshooting
Problem
Not Able ToLaunch Configurator > System repeatedly downloads and reinstalls J2RE 1.3.1_12 java plugin yantra 40 sp3 50 sp2 jre jdk sdk
Symptom
J2RE 1.3.1_12 java plugin yantra 40 sp3 50 sp3
PART: Platform 4.0
SP3 Platform
COMPONENT: Configurator - Java Plugin
WEB BROWSER:
Internet Explorer - 6.0 sp1
Cause
Resolving The Problem
dcm40sp3, needs 1.3.1 base java plugin
similarly Yantra 5.x and 7.x needs
1.3.1_09 java plugin
If you have ONLY a more recent version like
1.3.1_12,
the config applet tries to download its 'needed plugin' but sun
java will automatically suggest the latest 1.3.1_12,
which successfully
downloads and then has a problem again, because it isnt the version the applet
expects.
To get this running successfully, you will need to install
1.3.1 base available
on
http://java.sun.com/products/archive/j2se/1.3.1/index.html
or
http:/
/java.sun.com/products/archive/j2se/1.3.1_09/index.html
also accessible
to Yantra Support
in:
\\maui\support\Methodology\Infrastructure_Tools\Java\javaplugin
j2
re-1_3_1-win.exe and its associated jinstall-131-win32.rar
file
or
j2re-1_3_1_09-windows-i586.exe and its zipped version
j2re-1_3_1_09-windows-i586.zip
Install this and then open a new browser
and launch 40sp3 or 5.0 sp2 and then launch config and you should be all
fine.
Yantra Install Guide does advise the users to install the 1.3.1 base
version / 1.3.1_09 from the
link
http://java.sun.com/products/plugin/1.3.1/jinstall-131-win32.cab#Version
=1,3,1,0
but doesn't advise what to do if a more current version is
already installed on the client.
Historical Number
PRI49355
Product Synonym
[<p><b>]Fact[</b><p>];
Was this topic helpful?
Document Information
Modified date:
16 June 2018
UID
swg21549302
