IBM Support
How to add system and custom JVM properties to a traditional Content Platform Engine installation
Question & Answer
Question
How are system and custom JVM properties added to a traditional Content Platform Engine installation?
Answer
How to add system properties
Use one of the following procedures to add system and custom properties to a traditional Content Platform Engine installation. Refer to the following documentation for setting properties in a container installation: https://www.ibm.com/docs/en/filenet-p8-platform/5.5.x?topic=operators-content-platform-engine-parameters
WebSphere Application Server:
  1. Log in to WebSphere Integrated Solutions Console.
  2. Click Server > Application Servers > <server> > Server Infrastructure > Java and Process Management > process definition > Java Virtual Machine
  3. In the generic JVM arguments field, add the following:
    -D<system property>=<value>
  4. Save the changes and restart the application server.
Oracle WebLogic Server:
  1. Stop WebLogic Server.
  2. Open startWebLogic.cmd (Windows) or startWebLogic.sh (UNIX/Linux) from <WebLogic_home>\user_projects\domains\<domain>\bin folder.
  3. Add the following system properties to the JAVA_OPTS variable:
How to add custom properties by using the FileNet.properties file
Some system properties and custom properties can be set in the FileNet.properties file.
To add a property, open the FileNet.properties file and add property <property>=<value> to the file. Note -D is not part of the property name.
Place the FileNet.properties file in the application server startup directory. Following are the default application server startup directories:
  • WebSphere Application Server: <WebSphere_home>\AppServer\profiles\<profile name>
  • Oracle WebLogic Server: <WebLogic_home>\user_projects\domains\<domain>
[{"Type":"MASTER","Line of Business":{"code":"LOB45","label":"Automation"},"Business Unit":{"code":"BU053","label":"Cloud & Data Platform"},"Product":{"code":"SSNVNV","label":"FileNet Content Manager"},"ARM Category":[{"code":"a8m0z0000004D40AAE","label":"Content Engine"}],"ARM Case Number":"","Platform":[{"code":"PF025","label":"Platform Independent"}],"Version":"All Versions"}]
Document Information
Modified date:
12 October 2021
UID
swg21496579
