Messages and codes
Messages and codes provide reference information about
common events, configuration events, error codes, command-line interface
(CLI) events, and SCSI events.
Object types
You can use the object code to determine the type of the object the event is logged against.
Event IDs
The system software generates events, such as informational events and error events. An event ID or number is associated with the event and indicates the reason for the event.
Configuration event IDs
Configuration event IDs are generated when configuration parameters are set.
Using the error code tables
The error code tables list the various error codes and describe the actions that you can take.
Error event IDs and error codes
Error codes describe a service procedure that must be followed. Each event ID that requires service has an associated error code.
Command-line interface messages
The messages that display when you use the command-line interface (CLI) are listed here.
SCSI event reporting
Nodes can notify their hosts of events for SCSI commands that are issued.
