Setting up Connect:Direct Node on object store providers
By default, cloud support for Connect:Direct is not enabled. To enable cloud support, complete the following tasks:
Connect:Direct® for UNIX can also be configured to extend support to other S3 object store providers such as Minio, Dell EMC ECS, and Red Hat Ceph or use dedicated endpoints to execute public and on-premise cloud-based operations. For endpoint configuration/override see the dedicated section.
Pre-requisites to set-up Connect:Direct Unix on cloud provider
Before you configure Connect:Direct node definitions necessary for using Connect:Direct for UNIX, you must complete the following tasks:
  1. Set up cloud accounts and credentials
  2. Select and create a compute instance, RedHat or SuSE
  3. Create IAM user/roles
  4. Create Security group. Port numbers which are specific to Connect:Direct should be added to the security group
  5. Create storage
  6. Obtain credentials for cloud storage object access
For more information see, Account (amazon.com), Get started with Google Cloud | Documentation, IBM Cloud Docs, Azure documentation | Microsoft Docs
Installing Connect:Direct Unix node on Cloud
No specific configuration is required to install Connect:Direct for UNIX node on a compute instance. For information to install Connect:Direct for UNIX see, Installing Connect:Direct for UNIX.
If you are upgrading from an old release of Connect:Direct for UNIX node note that:
  • CD Unix, Linux platform, and JRE are now included in the base installation
  • Initparms to be included during the S3 plugin configuration are updated during the upgrade process
