iSeries Installation (V5.2.3 - 5.2.5)
You may follow different installation and upgrade scenarios when you install and upgrade Sterling B2B Integrator V5.2.0 - 5.2.5 in an iSeries environment.
Installation Scenarios for Version 5.2.5
Important: Review the following Sterling B2B Integrator installation and upgrade
scenarios.
Scenario | Instructions |
Version 5.2.4.1 or lower is installed as the base release and must be upgraded to version 5.2.5 on an iSeries installation that uses the IBM® i V5R4 operating system. |
Version 5.2.4.2 or lower is installed as the base release and must be upgraded to version 5.2.5 on an iSeries installation that uses the IBM i V6R1 operating system. |
Version 5.2.3 - 5.2.4.2 is installed as the base release and must be upgraded to version 5.2.5 on an iSeries installation that uses the IBM i V7R1 operating system. |
Version 5.2.3 - 5.2.4.2 is installed as the base release and must be upgraded to version 5.2.5 on an iSeries installation that uses the IBM i V7R2 operating system. |
Installation Scenarios for versions 5.2.3 - 5.2.4
scenarios.
Version 5.2.3.0 is being installed as the base release. | Review this document and use the installation instructions in Install the Software. |
Version 5.2.3.0 or lower is installed as the base release and it needs to be upgraded to the 5.2.3.x - 5.2.4.1 level. | Follow the Installing Sterling B2B Integrator version 5.2.3 - 5.2.4.2 as a fix pack instructions that are provided in Install the Software. |
Version 5.2.3.0 or lower is installed and it
needs to be upgraded to the 5.2.4.2 level on an iSeries using IBM i (i5/OS) V5R4. Note: This scenario requires an operating system upgrade. Sterling B2B Integrator 5.2.4.2 or higher is not
supported on IBM i V5R4. After you install the Sterling B2B Integrator 5.2.4.2 fix pack, you must
either upgrade your operating system or move your Sterling B2B Integrator instance to an iSeries using IBM i V6R1
or V7R1.
Version 5.2.3.0 or lower is installed as the base release and it needs to be upgraded to the 5.2.4.2 level on an iSeries using IBM i V6R1. |
Version 5.2.3.0 is installed as the base release and it needs to be upgraded to the 5.2.4.2 level on an iSeries using IBM i V7R1. | Follow the Installing Sterling B2B Integrator version 5.2.3 - 5.2.4.2 as a fix pack instructions that are provided in Install the Software. |
Version 5.2.4.0 is being installed as the base
release. Note: Sterling
B2B Integrator 5.2.4.0 can no longer be installed
instructions in Install the Software. Note: The SI_5050400.jar released in December 2013
automatically upgrades Sterling B2B Integrator to
5.2.4.2.
Version 5.2.4.0 is installed as the base release and it needs to be upgraded to the 5.2.4.1 level. | Follow the Installing Sterling B2B Integrator version 5.2.3 - 5.2.4.2 as a fix pack instructions that are provided in Install the Software. |
Version 5.2.4.0 or 5.2.4.1 is installed and
or V7R1.
Version 5.2.4.0 or 5.2.4.1 is installed as the base release and it needs to be upgraded to the 5.2.4.2 level on an iSeries using IBM i V6R1. |
Version 5.2.4.0 or 5.2.4.1 is installed as the base release and it needs to be upgraded to the 5.2.4.2 level on an iSeries using IBM i V7R1. | Follow the Installing Sterling B2B Integrator version 5.2.3 - 5.2.4.2 as a fix pack instructions that are provided in Install the Software. |
