IBM Explorer for z/OS
Version 3.0.1
Quick Start Guide
This guide describes a quick and easy way to install the product.
Product overview
IBM Explorer for z/OS V3.0.1 Aqua (z/OS Explorer) is an Eclipse-based integration platform for z/OS users. It enables the integration of a variety of offerings from IBM and other vendors, and in-house development plug-ins. z/OS Explorer is extendable via the IBM repository of compatible products to fulfill each user's roles and responsibilities. z/OS Explorer is also the strategic Eclipse platform for connectivity to key z/OS functions that are required by all z/OS application developers and system programmers.
Step 1: Access your software
Step 2: Access your documentation
Step 3: Evaluate the system requirements
Step 4: Install z/OS Explorer
To install z/OS Explorer host component, follow the installation instructions provided in the Program Directory for IBM Explorer for z/OS.
Step 5: Configure z/OS Explorer
- IBM Explorer for z/OS Host Configuration Quick Start Guide
- IBM Explorer for z/OS Host Configuration Utility Guide
- IBM Explorer for z/OS Host Configuration Guide
- IBM Explorer for z/OS Host Configuration Reference Guide
Step 6: Start z/OS Explorer
- If you installed z/OS Explorer by using IBM Installation Manager, go to the Windows Start menu and select Start > All Programs > IBM Software Delivery Platform > IBM Explorer for z/OS, or run eclipse.exe from the product installation directory.
- If you installed z/OS Explorer on an existing Eclipse instance by using Eclipse p2 update, run eclipse.exe from the product installation directory.
- If you downloaded the full z/OS Explorer package for Eclipse, run zosexplorer.exe from the product installation directory.
- If you installed z/OS Explorer by using IBM Installation Manager, go to the Applications menu and select , or run eclipse from the product installation directory.
- If you installed z/OS Explorer on an existing Eclipse instance by using Eclipse p2 update, run eclipse from the product installation directory.
- If you downloaded the full z/OS Explorer package for Eclipse, run zosexplorer from the product installation directory.
- If you installed z/OS Explorer by using IBM Installation Manager or the full z/OS Explorer package, go to the Applications menu and select , or run IBM Explorer for zOS from the product installation directory.
- If you installed z/OS Explorer on an existing Eclipse instance by using Eclipse p2 update, run IBM Explorer for zOS from the product installation directory.
More information
For FAQs, lists of known problems and fixes, visit the Fix list for IBM Explorer for z/OS.
