SMP cable isolation for 9080-MHE, 9080-MME, 9119-MHE, or 9119-MME
Use this information to isolate SMP cable problems for 9080-MHE, 9080-MME, 9119-MHE, or 9119-MME systems.
To isolate an SMP cable problem, complete the following steps:
- Is the reference code B114E504?
If Then Yes: Continue with the next step. No: Return to the procedure that sent you here. This ends the procedure. - Display the iqyylog.log file from the Hardware Management Console that is in the Enhanced Customer Data Repository (ECuRep). Find the reference code (+PEL) B114E504. Then, find the signature description that is displayed below the list of failing items for the reference code.
- A signature description contains a node number in the form of nx, an SCM
number in the form of px, and an "A bus" number in the form of
Ax or ABUSx.
In the following example, the node number is n1, the SCM number is p2, and the "A bus" number is ABUS0:
pu(n1p2) (IOAFIR[18]) ABUS0 Max Spares ExceededIn the following example, the node number is n0, the SCM number is p0, and the "A bus" number is A2:
pu(n0p0) (PBESFIR[14]) A2LINK_PSR_UNC_ERRRecord the node number, SCM number, and "A bus" number from the signature description that you identified for reference code B114E504.
- Use Table 1 and the node number, SCM number, and "A bus" number that you identified in step 3 to find the location code of one end of the SMP cable. Then, go to Cabling for 9080-MHE, 9080-MME, 9119-MHE, or 9119-MME to identify the other end of the SMP cable.
- Is the SMP cable fully seated at both of the port locations that you identified in step 4?
If Then Yes: Continue with step 7. No: Continue with the next step. - Complete the following steps:
- Fully seat the SMP cable at both of the port locations that you identified in step 4.
- Clear all of the deconfiguration errors. For instructions, see Clearing all deconfiguration errors.
- Power on the system. For instructions, see Powering on and powering off a system.
- Replace the SMP cable that you identified in step 4 and both of the processor modules that are indicated in the failing item list.
Does the problem persist?
If Then Yes: Continue with the next step. No: This ends the procedure. - Replace both of the system backplanes that are associated with the processor modules that you
replaced in step 7.
Table 1. Identifying the location code of the SMP cable port by using node number, SCM number, and "A bus" number Node number SCM number "A bus" number Location code of the SMP cable port n0 p0 A0 or ABUS0 U2: P1-C19-T3 n0 p0 A1 or ABUS1 U2: P1-C19-T2 n0 p0 A2 or ABUS2 U2: P1-C19-T1 n0 p1 A0 or ABUS0 U2: P1-C14-T6 n0 p1 A1 or ABUS1 U2: P1-C14-T5 n0 p1 A2 or ABUS2 U2: P1-C14-T4 n0 p2 A0 or ABUS0 U2: P1-C18-T3 n0 p2 A1 or ABUS1 U2: P1-C18-T2 n0 p2 A2 or ABUS2 U2: P1-C18-T1 n0 p3 A0 or ABUS0 U2: P1-C15-T6 n0 p3 A1 or ABUS1 U2: P1-C15-T5 n0 p3 A2 or ABUS2 U2: P1-C15-T4 n1 p0 A0 or ABUS0 U4: P1-C19-T3 n1 p0 A1 or ABUS1 U4: P1-C19-T2 n1 p0 A2 or ABUS2 U4: P1-C19-T1 n1 p1 A0 or ABUS0 U4: P1-C14-T6 n1 p1 A1 or ABUS1 U4: P1-C14-T5 n1 p1 A2 or ABUS2 U4: P1-C14-T4 n1 p2 A0 or ABUS0 U4: P1-C18-T3 n1 p2 A1 or ABUS1 U4: P1-C18-T2 n1 p2 A2 or ABUS2 U4: P1-C18-T1 n1 p3 A0 or ABUS0 U4: P1-C15-T6 n1 p3 A1 or ABUS1 U4: P1-C15-T5 n1 p3 A2 or ABUS2 U4: P1-C15-T4 n2 p0 A0 or ABUS0 U5: P1-C19-T3 n2 p0 A1 or ABUS1 U5: P1-C19-T2 n2 p0 A2 or ABUS2 U5: P1-C19-T1 n2 p1 A0 or ABUS0 U5: P1-C14-T6 n2 p1 A1 or ABUS1 U5: P1-C14-T5 n2 p1 A2 or ABUS2 U5: P1-C14-T4 n2 p2 A0 or ABUS0 U5: P1-C18-T3 n2 p2 A1 or ABUS1 U5: P1-C18-T2 n2 p2 A2 or ABUS2 U5: P1-C18-T1 n2 p3 A0 or ABUS0 U5: P1-C15-T6 n2 p3 A1 or ABUS1 U5: P1-C15-T5 n2 p3 A2 or ABUS2 U5: P1-C15-T4 n3 p0 A0 or ABUS0 U1: P1-C19-T3 n3 p0 A1 or ABUS1 U1: P1-C19-T2 n3 p0 A2 or ABUS2 U1: P1-C19-T1 n3 p1 A0 or ABUS0 U1: P1-C14-T6 n3 p1 A1 or ABUS1 U1: P1-C14-T5 n3 p1 A2 or ABUS2 U1: P1-C14-T4 n3 p2 A0 or ABUS0 U1: P1-C18-T3 n3 p2 A1 or ABUS1 U1: P1-C18-T2 n3 p2 A2 or ABUS2 U1: P1-C18-T1 n3 p3 A0 or ABUS0 U1: P1-C15-T6 n3 p3 A1 or ABUS1 U1: P1-C15-T5 n3 p3 A2 or ABUS2 U1: P1-C15-T4
Parent topic: Common service procedures
