Customize the background color for data and header cells
In the new experience view, you can now customize the background color of data cells and row and column header cells to any color from the palette or custom color selector.
To customize the background color of cells in the new experience view:
  1. In Edit mode, go to Properties.
  2. Click Custom and expand Text properties.
  3. Select the cell type for which you want to change the color.
  4. Click Fill color and select a new color. Optionally, use Select custom color to create your own color with the Color picker.
    Text properties menu
