Removing and replacing a disk drive or SSD in the 5147-024, ESLL, or ESLS storage enclosure with the power turned on in Linux
Learn how to remove and replace a disk drive or solid-state drive (SSD) in an enclosure with the Linux operating system or a Linux logical partition that controls the drive location powered on.
To remove and replace a disk drive or solid-state drive in a system, complete the following steps:
Note: Removing or replacing this feature is
a customer task. You can complete this task yourself, or contact a
service provider to complete the task for you. You might be charged
a fee by the service provider for this service.
