Volume groups
Find information about volume groups.
A volume group is a collection of one or more physical volumes of varying sizes and types. A physical volume can belong to only one volume group per system. There can be up to 4096 active volume groups on the Virtual I/O Server.
When a physical volume is assigned to a volume group, the physical blocks of storage media on it are organized into physical partitions of a size determined by the system when you create the volume group. For more information, see Physical Partitions.
When you install the Virtual I/O Server, the root volume group called rootvg is automatically created that contains the base set of logical volumes required to start the system logical partition. The rootvg includes paging space, the journal log, boot data, and dump storage, each in its own separate logical volume. The rootvg has attributes that differ from user-defined volume groups. For example, the rootvg cannot be imported or exported. When using a command or procedure on the rootvg, you must be familiar with its unique characteristics.
Table 1. Frequently used volume group commands and their descriptions
Command Description
activatevg Activates a volume group
chvg Changes the attributes of a volume group
deactivatevg Deactivates a volume group
exportvg Exports the definition of a volume group
extendvg Adds a physical volume to a volume group
importvg Imports a new volume group definition
lsvg Displays information about a volume group
mkvg Creates a volume group
reducevg Removes a physical volume from a volume group
syncvg Synchronizes logical volume copies that are not current
Small systems might require only one volume group to contain all of the physical volumes (beyond the rootvg volume group). You can create separate volume groups to make maintenance easier because groups other than the one being serviced can remain active. Because the rootvg must always be online, it contains only the minimum number of physical volumes necessary for system operation. It is recommended that the rootvg not be used for client data.
You can move data from one physical volume to other physical volumes in the same volume group by using the migratepv command. This command allows you to free a physical volume so it can be removed from the volume group. For example, you could move data from a physical volume that is to be replaced.
