Use the Manufacturing Perspective to create or update an existing client item for App Connect for Manufacturing nodes so that the OPC UA Server data is available
in your message flow.
Procedure
- Open the Manufacturing Perspective window using any of the following
methods.
- Open Toolkit and navigate to .
- In the Properties view for a node, click Add or
Select.
- The Manufacturing Perspective window has following views.
Table 1. Manufacturing Perspective
| View |
Description |
User task |
| DataSources |
Displays the data source that is configured to connect to your OPC UA Server. You can have
more than one data source. |
You can perform the following tasks:
- Add a Mapping Node
- Rename Mapping Node
- Delete Mapping Node
- Delete Mapping Node's Target
- Duplicate Mapping Node
- Refresh Source Item Tree
| Source Items |
Displays the data for the OPC UA Server source items in a tree structure view. |
Browse the OPC UA Server address space. Select a Source Item to be mapped to a Client
Item. |
| Client Items |
Displays the list of client items available, which are created and mapped to source items. |
| DataSource Properties |
Displays the DataSource connection properties that are used to establish connection with an
OPC UA Server. |
- Create Data Source
- Update Data Source
| Client Item Value |
After the client item is created and mapped to a source item, the client item values are
populated. Displays the values of a client item that is mapped to a source item. |
| Client Item Properties |
After the client item is created and mapped to a source item, the client item path values are
populated. |
- Create Client Item
- Update Client Item
- Create Client Item Tree
| Logging |
Displays the status of each activity that is performed in the manufacturing
perspective. |
| Select |
- OPC-UA-Input node
- Displays association of a Client Item with a manufacturing node.
- Add Trigger Item
- Add Item to Trigger
- Add Client Item to Read
- Add Client Item to Write
- Select for Method Call
- Cancel
- Update as required and click OK.
