load-parser
Global named parser reference
Usage
The element referenced can be stored in and retrieved from the repository.
Description
This can be used to force a parser to be loaded into memory for use later.
Attributes
  • async (Boolean default: true) - Asynchronous processing. For parse tags, should the request be enqueued (false) or processed before its next sibling. For other elements, this attribute only makes a difference when they contain asynchronous requests which need to be processed before the element is processed. In this case, when false the element's next sibling will only be processed after the current element, when true Watson™ Explorer won't wait for the current element to be processed before processing its next sibling.
  • elt-id (Integer) - Usage: Internal
  • max-elt-id (Integer) - Usage: Internal
  • execute-acl (Text)
  • process (Text) - An XPath determining which of the attributes and/or children will be processed. Currently only "", "*", "@*" and "*|@*" are supported.
  • name (NMToken) - The name of the parser to load. Usage: Must be specified once all the child elements have been processed
