Upgrading your HMC software
Learn how to upgrade the software on an HMC from one release to the next while you maintain your HMC configuration data.
About this task
Note: For HMC models 7063-CR1 and 7063-CR2,
you can connect an external USB DVD drive.
Step 1. Obtain the upgrade
About this task
You can order the HMC machine code upgrade through the Fix Central website.
To obtain the upgrade through the Fix Central website, complete the following steps:
Procedure
Step 2. View the existing HMC machine code level
About this task
Procedure
In the navigation area, click the HMC
Management icon
, and then select Console Management. In the navigation area, click
Updates.
- In the content pane, click Update the Hardware Management Console.
- In the new window, view and record the information that appears under the Current HMC Driver information heading, including the HMC version, release, maintenance level, build level, and base versions.
- Continue with Step 3. Back up the managed system's profile data.
About this task
To back up the managed system's profile data, complete the following steps:
Procedure
- Select the system that you want to save the profile data.
- Click .
- Type a backup file name and record this information.
- Click OK.
- Repeat these steps for each system.
- Continue with Step 4. Back up HMC data.
About this task
Note: To back up to
removable media, you need to have that media available.
To back up HMC data, complete the following steps:
Procedure
Step 5. Record the current HMC configuration information
About this task
To record the current HMC configuration, complete the following steps:
Procedure
Step 6. Record remote command status
About this task
To record remote command status, complete the following steps:
Procedure
In the navigation area, click the Users and Security icon
, and then select Systems and Console Security.
- In the content pane, click Enable Remote Command Execution.
- Record whether the Enable remote command execution using the ssh facility check box is selected.
- Click Cancel.
- Continue with Step 7. Save upgrade data.
About this task
Note: Only one level of
backup data is allowed. Each time that you save upgrade data, the previous level is
overwritten.
To save upgrade data, complete the following steps:
Procedure
Step 8. Upgrade the HMC software
About this task
Procedure
Step 9. Verify that the HMC machine code upgrade installed successfully
About this task
Procedure
Management icon
- Verify that the version and release match the update that you installed.
- If the level of code that is displayed is not the level that you installed, retry the upgrade task by using a new DVD. If the problem persists, contact your next level of support.
, and then select
