Tape cartridges (FC 6258)
Learn about the types of tape cartridges that are available for this drive.
Available tape cartridges
Table 1. 4-mm Data Cartridges
IBM® Part Number Type of Cartridge Native (uncompressed) Capacity
18P7912 DAT 72 Data Cartridge 36 GB
59H4457 4-mm Test Cartridge --
21F8763 4-mm Cleaning Cartridge --
59H3465 Data Cartridge DDS3 12GB
59H4458 Data Cartridge DDS4 20GB
Most bulk eraser devices do not have the capability to erase the 4mm data cartridge. To correctly erase a 4mm data cartridge with a bulk eraser device, the erasure coercivity rating must be a minimum of 3900 Oersted.
