Assembly diagrams.
Index number | Part number | Units per assembly | Description |
1 | 12R9749* |
1 | Bulk power assembly. For a detailed parts list see the Bulk power assembly (BPA). |
2 | 77G0599* |
2 | Screw, BPE mounting |
3 | 74F1823* |
5 | Nut clip |
4 | 15R6747* |
1 | Unit emergency power off (UEPO) switch assembly |
5 | 2665528* |
2 | Screw, UEPO mounting |
6 | 11P3843* |
1 | Cable bracket |
7 | 77G0599* |
3 | Screw, cable bracket |
8 | 12R9758* |
1 | Mount, right |
9 | 77G0599* |
2 | Screw |
10 | NONUM | AR | Processor subsystem assembly. For a detailed parts list see the Processor subsystem assembly. |
11 | 12R9757* |
1 | Mount, left |
12 | 77G0599* |
2 | Screw |
13 | 41U0012* |
AR | Internal battery feature (IBF) |
14 | 77G0599* |
2 | Screw |
15 | NONUM | 2 | Washer |
16 | 74F1823* |
2 | Nut clip |
* Designed to comply with RoHS requirement
** Not designed to comply with RoHS requirement
1 | 41U0388* |
AR | Cover kit (acoustical) |
41U0386* |
AR | Cover kit (slim) | |
44P2670** |
AR | Filter, cover | |
44P4573* |
Front cover | ||
2 | 11P4106* |
2 | Hinge, back cover |
3 | 2665525* |
4 | Screw, hinge |
4 | 12R8782* |
2 | Cover, right-side |
5 | 54G2882* |
3 | Screw, cover mounting |
6 | 44P0125** |
2 | Cover, left-side |
7 | 54G2882* |
8 | 11P3535* |
2 | Hinge, front cover |
9 | 2665525* |
4 | Screw, hinge |
10 | See index number 1 | 1 | Cover kit |
1 | 12R7800* |
2 | Depth reduction kit, support bars |
2 | NONUM | 8 | Screw |
3 | 12R6703* |
1 | Extender, top |
4 | NONUM | 4 | Screw |
5 | 12R7805* |
1 | Extender, right side |
6 | NONUM | 3 | Screw |
7 | 12R7806* |
1 | Extender, left side |
8 | NONUM | 3 | Screw |
9 | NONUM | 1 | Bracket, ESD |
10 | 54G2882* |
2 | Screw |
11 | 12R6709* |
1 | Support bar |
12 | NONUM | 4 | Screw |
13 | 12R8702* |
2 | Extender side cover |
14 | 77G0599* |
6 | Screw |
15 | 12R9733* |
1 | Tailgate, back |
15 | 12R8313* |
16 | 77G0599* |
2 | Screw |
1 | 12R9749* |
1 | Bulk power assembly |
2 | See Power parts | AR | Bulk power jumper |
See Power parts | AR | Bulk power hub | |
See Power parts | AR | Bulk power distribution assembly | |
3 | See Power parts | AR | Bulk power controller assembly |
4 | See Power parts | AR | Bulk power regulator assembly |
5 | See Power parts | 1 | Bulk power fan |
6 | 44P0550* |
1 | Cover, bulk power fan |
1 | See Power parts | 1 | Power supply assembly |
2 | See Memory parts | AR | Memory card |
44H8167* |
AR | Filler, memory card | |
3 | 41V1610* |
1 | Fan assembly |
4 | See Backplane parts | 1 | Processor subsystem assembly backplane |
5 | See Backplane parts | 1 | I/O assembly |
6 | See System parts | AR | PCI adapter |
16R0091* |
AR | PCI adapter cassette | |
6 | See System parts | AR | GX card |
7 | 16R0802* |
AR | Filler, GX card |
8 | See VPD parts | 1 | VPD card |
9 | See Disk unit parts | 2 | Disk drive |
