Assembly diagrams.
Index number | Part number | Units per assembly | Description |
1 | NONUM | AR | Cable arm |
2 | 39M6938* 90P4069** |
1 | Rail kit |
3 | 39J0315* | 1 | Cover, model 510 |
3 | 97P5841* | 1 | Front bezel, model OpenPower 710 |
3 | 39J3381** | 1 | Front bezel, model 9110-51A |
* Designed to comply with RoHS requirement
** Not designed to comply with RoHS requirement
4 | 97P5817** | 1 | Top cover |
5 | See Backplane parts | 1 | Enclosure, PCI adapter |
See System parts | AR | PCI adapter | |
6 | NONUM | 1 | Air dam |
7 | See Disk unit parts | AR | Disk unit |
97P4179* 53P6213** |
AR | Filler, disk unit | |
8 | 97P5819* | 2 | Blower |
97P6840* | 2 | Cable, fan | |
9 | See Removable media device parts | AR | Removable media |
53P5867* | AR | Filler, removable media | |
10 | See Control panel parts | 1 | Control panel and removable media tray assembly |
11 | See Power parts | AR | Power supply |
39J0534* 97P5843** |
AR | Filler, power supply | |
12 | See VPD parts | 1 | VPD card |
13 | See Backplane parts | 1 | System backplane |
14 | 39J0199* | AR | Screw, system backplane |
15 | NONUM | 1 | Bracket, support |
16 | NONUM | AR | Screw, support bracket |
17 | 40K6435* | 1 | Right latch |
18 | 27F4212** | 2 | Latch screw |
19 | 40K6434* | 1 | Left latch |
See Memory parts | AR | Memory card | |
44H8167* | AR | Filler, memory card | |
See Power parts | Voltage regulator, 1.3 | ||
See Power parts | Voltage regulator, 2.5 | ||
See Power parts | Battery |
