Connecting and configuring the 5786, 5787, 7031-D24 or 7031-T24 SCSI disk-drive enclosure in an AIX® clustered environment
Special considerations exist for connecting the disk-drive enclosure in a clustered environment. The information in this section will help you meet these considerations.
Having any planning and cabling documentation for the system you are attaching available during this process will make some parts of this process much easier.
To assure that the SCSI disk-drive enclosure is ready to be connected to the cluster complete the following steps.
  1. Ensure that each SCSI device connected to the shared SCSI bus has a unique ID. A common configuration is to set the SCSI ID of the adapters on the nodes to be higher than the SCSI IDs of the shared devices. (Devices with higher IDs take precedence in SCSI bus contention.)
    1. Use the command: lscfg | grep scsi to determine and record the logical name of each adapter. In the command output, the first column lists the logical name of the SCSI adapter, such as + SCSI0.
    2. Use the lscfg -vpl command and logical name of the adapter to record the I/O slot (physical slot) that each SCSI adapter uses. For example lscfg -vpl scsi0 where scsi0 is the logical name of the adapter.
    3. Use the lsattr command, as in the following example to find the ID of the adapter scsi0: lsattr -E -l scsi0 | grep id
      Note: Do not use wildcard characters or full pathnames on the command line for the device name designation.
      In the resulting output, the first column lists the attribute names. The integer to the right of the id attribute is the adapter SCSI ID:
    If a SCSI adapter address conflict exists move on to the next step, if no conflict exists return to the connection page for the operating system of the system you are connecting.
  2. Examine the cabling to see if the proper ports on the system are connected to the proper ports on the repeater cards on the disk-drive enclosure. For example if you are connecting the system using two host adapter cards and dual repeater cards as shown in the following figure you will want to connect the systems as follows.
    Figure 1. SCSI cable to dual repeater card connected with two SCSI cards
    SCSI cable to repeater card.
    Cable the first SCSI bus or set of shared disks by doing the following:
    1. Connect the bottom port of the adapter on Host A (SCSI address 7) to the exterior port on the repeater card in slot C2 on the enclosure.
    2. Connect the top port of the adapter on Host B (SCSI address 6) to the exterior port on the repeater card in slot C3 on the enclosure.
    This creates a set of shared disks and a shared SCSI bus (such as scsi0) between Host A and Host B. The important thing to consider at this point is that you connect the cables in descending order of the SCSI address on the host adapter. Connecting the cables in descending order of the Host SCSI address will reduce the potential for address conflicts.
    Cable the second SCSI bus or set of shared disks by doing the following:
    1. Connect the bottom port of the adapter on Host B (SCSI address 7) to the interior port on the repeater card in slot C5 on the enclosure.
    2. Connect the top port of the adapter on Host A (SCSI address 6) to the interior port on the repeater card in slot C4 on the enclosure.
    This creates a set of shared disks and a shared SCSI bus (such as scsi1) between Host A and Host B. The important thing to consider at this point is that this is an independent SCSI bus or set of shared disks from the first set. Ensuring that you do not mistakenly connect one of the cables from the either SCSI bus to another will reduce the potential for SCSI address conflicts.
    Important: When adding, removing, or replacing SCSI adapters in Host systems you might want to disconnect the cabling at the enclosure first and reconnect the cabling to the enclosure last. This is because the new adapter may default to a SCSI ID of 7. You should ensure that the correct SCSI ID is set for the port you are cabling.
