February 28, 2024 By Terry Bernstein 3 min read
The chief difference between a CNAME record and an ALIAS record is not in the result—both point to another DNS record—but in how they resolve the target DNS record when queried. As a result of this difference, one is safe to use at the zone apex (for example, naked domain such as example.com), while the other is not.
Let’s start with the CNAME record type. It simply points a DNS name, like www.example.com, at another DNS name, like lb.example.net.  This tells the resolver to look up the answer at the reference name for all DNS types (for example, A, AAAA, MX, NS, SOA, and others). This introduces a performance penalty, since at least one additional DNS lookup must be performed to resolve the target (lb.example.net). In the case of neither record ever having been queried before by your recursive resolver, it’s even more expensive timewise, as the full DNS hierarchy may be traversed for both records:
  1. You as the DNS client (or stub resolver) query your recursive resolver for www.example.com.
  2. Your recursive resolver queries the root name server for www.example.com.
  3. The root name server refers your recursive resolver to the .com Top-Level Domain (TLD) authoritative server.
  4. Your recursive resolver queries the .com TLD authoritative server for www.example.com.
  5. The .com TLD authoritative server refers your recursive server to the authoritative servers for example.com.
  6. Your recursive resolver queries the authoritative servers for www.example.com and receives lb.example.net as the answer.
  7. Your recursive resolver caches the answer and returns it to you.
  8. You now issue a second query to your recursive resolver for lb.example.net.
  9. Your recursive resolver queries the root name server for lb.example.net.
  10. The root name server refers your recursive resolver to the .net Top-Level Domain (TLD) authoritative server.
  11. Your recursive resolver queries the .net TLD authoritative server for lb.example.net.
  12. The .net TLD authoritative server refers your recursive server to the authoritative servers for example.net.
  13. Your recursive resolver queries the authoritative servers for lb.example.net and receives an IP address as the answer.
  14. Your recursive resolver caches the answer and returns it to you.
Each of these steps consumes at least several milliseconds, often more, depending on network conditions. This can add up to a considerable amount of time that you spend waiting for the final, actionable answer of an IP address.
In the case of an ALIAS record, all the same actions are taken as with the CNAME, except the authoritative server for example.com performs steps six through thirteen for you and returns the final answer as both an IPv4 and IPv6 address. This offers two advantages and one significant drawback:
Advantages
Faster final answer resolution speed
In most cases, the authoritative servers for example.com will have the answer cached and thus can return the answer very quickly.
The alias response will be A and AAAA records. Since an ALIAS record returns the answer that comprises one or more IP addresses, it can be used anywhere an A or AAAA record can be used—including the zone apex. This makes it more flexible than a CNAME, which cannot be used at the zone apex.  The flexibility of the Alias record is needed when your site is posted on some of the most popular CDNs that require the use of CNAME records if you want your users to be able to access it via the naked domain such as example.com.
Disadvantages
Geotargeting information is lost
Since it is the authoritative server for example.com that is issuing the queries for lb.example.net, then any intelligent routing functionality on the lb.example.net record will act upon the location of the authoritative server, not on your location. The EDNS0 edns-client-subnet option does not apply here. This means that you may be potentially mis-routed: for example, if you are in New York and the authoritative server for example.com is in California, then lb.example.com will believe you to be in California and will return an answer that is distinctly sub-optimal for you in New York.  However, if you are using a DNS provider with worldwide pops, then it is likely that the authoritative DNS server will be located in your region, thus mitigating this issue.
One important thing to note is that NS1 collapses CNAME records, provided that they all fall within the NS1 system. NS1’s nameservers are authoritative for both the CNAME and the target record. Collapsing simply means that the NS1 nameserver will return the full chain of records, from CNAME to final answer, in a single response. This eliminates all the additional lookup steps and allows you to use CNAME records, even in a nested configuration, without any performance penalty.
And even better, NS1 supports a unique record type called a Linked Record. This is basically a symbolic link within our platform that acts as an ALIAS record might, except with sub-microsecond resolution speed. To use a Linked Record, simply create the target record as you usually would (it can be of any type) and then create a second record to point to it and select the Linked Record option. Note that Linked Records can cross domain (zone) boundaries and even account boundaries within NS1 and offer a powerful way to organize and optimize your DNS record structure.
CNAME, ALIAS and Linked Record Reference Chart
 CNAMEALIASLinked Record
Use at Apex?NoYesYes (only to other NS1 zones)
Relative Speed (TTFB)FastFasterFaster
Collapses ResponsesYes (NS1 Connect exclusive feature)YesYes
Scroll to view full table
INSERT DISPLAY TEXT HERE
Was this article helpful?
YesNo
More from Automation
IBM continues to support OpenSource AsyncAPI in breaking the boundaries of event driven architectures
3 min read - IBM® Event Automation’s event endpoint management capability makes it easy to describe and document your Kafka topics (event sources) according to the open source AsyncAPI Specification. Why is this important? AsyncAPI already fuels clarity, standardization, interoperability, real-time responsiveness and beyond. Event endpoint management brings this to your ecosystem and helps you seamlessly manage the complexities of modern applications and systems. The immense utility of Application Programming Interfaces (APIs) and API management are already widely recognized as it enables developers to collaborate…
Generative AI meets application modernization
2 min read - According to a survey of more than 400 top IT executives across industries in North America, three in four respondents say they still have disparate systems using traditional technologies and tools in their organizations. Furthermore, the survey finds that most executives report being in the planning or preliminary stages of modernization. Maintaining these traditional, legacy technologies and tools, often referred to as “technical debt,” for too long can have serious consequences, such as stalled development projects, cybersecurity exposures and operational…
Maximize business potential with IBM API Connect and the Open Network for Digital Commerce
4 min read - Imagine a marketplace where even the smallest local shop can compete with big-name brands, reaching customers far and wide. This is the promise of the Open Network for Digital Commerce (ONDC) in India. By integrating it with IBM API Connect®, businesses can unlock new growth opportunities and elevate their digital presence.   Let’s dive into how this integration works and why it’s so innovative.  What are IBM API Connect and ONDC?  Think of IBM API Connect as your ultimate toolkit…
IBM Newsletters
