Picture this: You’re at your local supermarket, eagerly exploring the fresh produce section. You carefully select a carton of ripe, juicy fresh-cut strawberries, envisioning them as the star ingredient in your weekend’s mouthwatering desserts. You’re all set to enjoy a delightful culinary adventure. But as you savor your first bite of a luscious strawberry shortcake, you receive a notification on your smartphone. It’s breaking news: a food recall alert! Panic ensues as you wonder if those very strawberries are part of the recall, and you hastily check the label.
Now, while this might sound like a scene from a suspenseful thriller, it’s a real-life dilemma that food businesses face. In a world where food safety is paramount, compliance with the FDA Food Tracebility Rule FSMA 204 is non-negotiable.
Fortunately, in the ever-evolving world of food safety, a dynamic partnership between IBM and iFoodDS is rewriting the script, offering a solution that not only ensures compliance but also elevates food safety to new heights.
The FDA’s Food Safety Modernization Act (FSMA) Rule 204 is a game-changer for food traceability. This new regulation requires food companies that manufacture, process, pack, or hold foods on the Food Traceability List (FTL) implement traceability systems and new record keeping requirements. The goal of the regulation is to help prevent foodborne illness outbreaks by making it easier to track the movement of food from farm to fork. Today, outbreak investigations take an average of a month to complete, often with inconclusive results.1
The impact of the FSMA Rule 204(d) on traceability is significant. For the first time, the industry will be required to collect and maintain detailed information about the ingredients, processing, and distribution of their products. This information will be used to create a “traceability chain” that can be used to quickly identify and remove contaminated food from the market. The FDA estimates that the rule will help reduce outbreak investigations to less than one week.2
The FSMA Rule 204(d) is a complex regulation, and it will take time for the food industry to comply, however, IBM and iFoodDS are partnering to make it easier for companies to meet the upcoming compliance deadline.
The joint offering—called iFoodDS Trace Exchange with IBM Food Trust—will offer businesses in the food industry and their suppliers a comprehensive, scalable, and secure traceability solution that meets the requirements of FSMA Rule 204. Under the partnership, IBM will provide the backend data processing and storage capabilities on the IBM Food Trust network, while iFoodDS will provide a suite of applications and deep industry knowledge to assist companies with onboarding and organizational change needed to collect the required Key Data Elements (KDEs) and Critical Tracking Events (CTEs).
The joint solution will offer several benefits for food companies, including:
  • The most comprehensive solution for FDA FSMA 204 compliance: The solution will cover all the requirements of FSMA Rule 204, including the ability to capture, store, share, monitor and report on traceability data for all foods on the Food Traceability List (FTL).
  • Unmatched onboarding experience: iFoodDS has a deep understanding of the food industry and can provide food companies with a seamless onboarding experience. This includes helping companies to assess their current traceability capabilities, develop a compliance plan, and implement the solution.
  • Purpose-built FSMA 204 data capture applications & methods: The solution includes a suite of purpose-built applications and methods for capturing the required KDEs and CTEs. This makes it easy for food companies to comply with the regulations without having to develop their own solutions.
  • The most scalable and secure tech-enabled traceability solution in the industry: The solution is built on the IBM Food Trust network, which is a secure and scalable blockchain platform that can support the traceability needs of even the largest food companies.
  • Trusted data sharing: The solution allows food companies to share traceability data with their trading partners in a secure and trusted manner. This allows companies to meet the requirements of the rule while providing visibility to help them run their supply chains more efficiently.
The partnership between IBM and iFoodDS is a significant step forward for food safety. The joint solution will help the industry achieve FSMA 204 compliance and improve food safety across the entire supply chain.
In addition to the benefits mentioned above, the partnership between IBM and iFoodDS also has the potential to:
  • Recall food faster and more efficiently to reduce illness and waste: By making it easier for food companies to track the movement of food, the joint solution can help to reduce the number of foodborne illness outbreaks.
  • Improve food waste reduction: By enabling a better understanding of the supply chain, the joint solution can help to reduce food waste.
  • Increase food transparency: By making traceability data more accessible to consumers, the joint solution can increase food transparency and consumer confidence.
The partnership between IBM and iFoodDS has yielded a game-changing solution for the food industry, one that not only meets the stringent requirements of the FDA FSMA Rule 204(d) but also advances global food safety. iFoodDS Trace Exchange with IBM Food Trust is poised to make compliance effortless, data management secure, and traceability swift and accurate, ultimately ensuring safer food for consumers around the world. As the industry embarks on this transformative journey, it’s a clear signal we have truly entered a new era of smarter food safety.
Explore Food Traceability Software for the Whole Supply Chain
  1. CDC Update on Investigation of Multistate Outbreak of E. coli O157:H7 Infections Linked to Romaine Lettuce
  2. Final Regulatory Impact Analysis (Table 9)
Was this article helpful?
YesNo
More from Sustainability
Increase efficiency in asset lifecycle management with Maximo Application Suite’s new AI-powered features
6 min read - It can be a daunting task to manage and maintain a complex system of assets for daily operational success. Organizations must constantly consolidate information from various sources and address issues in real time while also focusing on how to best innovate. The cost of unplanned downtime is increasing, skills shortages are hurting productivity, and sustainability initiatives increasingly pose a challenge to traditional maintenance practices.  To address these challenges, companies must use technology that can provide intelligent and comprehensive asset management…
AI-infused sustainability planning and forecasting with Envizi
2 min read - As climate disclosure requirements continue to grow as part of environmental, social and governance reporting, many businesses are seeking to steer their path effectively toward meeting their emissions reduction targets. However, existing planning and forecasting tools are not well equipped to manage ESG data models.  To help address this challenge, IBM is pleased to announce the addition of enhanced planning and forecasting capability to the IBM® Envizi™ ESG Suite from 21 May 2024.   IBM Envizi’s planning and forecasting solution…
How generative AI will revolutionize supply chain
2 min read - Unlocking the full potential of supply chain management has long been a goal for businesses that seek efficiency, resilience and sustainability. In the age of digital transformation, the integration of advanced technologies like generative artificial intelligence brings a new era of innovation and optimization. AI tools help users address queries and resolve alerts by using supply chain data, and natural language processing helps analysts access inventory, order and shipment data for decision-making.  A recent IBM Institute of Business Value study,…
IBM Newsletters
