My IBM Log in
Need to build applications that can easily scale to spikes in demand? We understand your pain!
This requires large amounts of engineering work to set up the right infrastructure and run the application. On top of that, it means you’ll need a good deal of operational support to keep it running and maintain the underlying infrastructure. It’s a significant investment just to get the thing off the ground. The good news is, this is no longer an issue. Why? Because you can build serverless applications through the IBM Cloud Functions Platform.
This means:
  • No more up-front engineering since there’s no infrastructure to set up
  • No more operational support since there’s no infrastructure to maintain
Edge Functions on IBM Cloud Internet Services
With IBM Cloud Functions, customers can run complex applications without incurring costs associated with traditional infrastructure. What’s better than serverless applications? Serverless capability at the network edge.
We bring you Edge Functions on IBM Cloud Internet Services (CIS) to provide you with serverless computing at the edge along with all the security features of the CIS proxy, including DDoS protection, WAF, Browser Integrity Check, and more. This means you can run the serverless applications at the network edge, closer to your users across 180+ global network PoPs.
Edge Functions allows developers to build simple applications that can be completely serviced by the offering. Moreover, CIS’s Edge Functions can also be used for more complex layered applications that offload pre/post-processing of a complex application at the network edge for faster, more secure, and customized responses. More complex pieces of the application can be handled by the serverless IBM Cloud Functions or a traditional web application, all while optimizing security and reliability for your public-facing application through CIS.
What is Edge Functions?
Edge Functions allows you to run code closer to users of your public-facing applications or websites. In turn, you can improve your application’s performance and reduce latency. This means you can quickly create new applications or modify existing ones without having to configure or maintain infrastructure via our serverless execution environment. Once a new application is deployed or an existing application is modified, it takes us ~15 seconds to get the changes distributed globally to our 180+ PoPs worldwide.
Edge Functions allows you to pre-process HTTP requests before they reach the application origin servers and post-process any responses from the application. With this powerful capability at the edge, you can create applications that deliver personalized user experiences, increase API responsiveness, implement custom application security, and much more. For example, you can write an edge functions application that invokes multiple Cloud Functions or APIs, aggregates the responses, and provides the client with a consolidated response.
Under the hood, the Edge Functions runtime uses the V8 engine used by Chromium and Node.js. The V8 engine orchestrates “isolates”—lightweight contexts that group variables with the code allowed to mutate them. You can consider an isolate as a sandbox for your edge function to run in, instead of creating a virtual machine or invoking a container. Isolates are designed to start within an existing runtime environment without allowing an isolate to access memory for another isolate.
How can I use Edge Functions?
Edge Functions works best for creating custom experiences for your end user. This can take the form in a variety of use cases:
  • You can create a CIS Edge Function to control A/B tests. You can do this by intercepting inbound HTTP(S) requests and serving content requests from the Edge Functions and CIS’s caching feature to specific control and test groups.
  • Deliver personalized user experiences through conditional routing and originless responses. Imagine you receive a request to admit from a potential hacker. This provides you with the ability to easily determine their intent and divert them to a different page for them to do their dirty work while your application remains safe, secure, and reliable. You can do this, and more, by building responses from multiple background service requests either to the Cloudflare cache, application origin, or third-party APIs.
  • Increase API responsiveness by creating a flexible API gateway to aggregate responses from multiple endpoints and return as a single response. This eliminates the need for each endpoint to compile individual responses. Each request can also be split into multiple parallel requests and then combined into a single response. This increases API responsiveness.
  • Implement custom application security by building conditional responses for inbound requests that can assess and subsequently block or reroute malicious or unauthorized requests. You can also set parameters that identify and authorize legitimate application traffic. Examples of this include the following:
Get started today
With IBM Cloud Internet Services, you can easily create and update your public-facing web applications and quickly deliver them globally. By building your public-facing websites and applications with us you will get:
  • Optimized performance and reliability: Run your code quickly and deliver static and dynamic content to your users wherever they are, without sacrificing latency
  • Better responsiveness: You can quickly scale out your code globally with our isolate approach to help you get going and make changes faster.
  • More flexibility: With Edge Functions in combination with Cloud Functions, we offer you the most flexible solutions to create custom end-user experiences without compromise—the ability to execute serverless functions at the edge in concert with (or without) a centralized data center application (serverless or otherwise). Save your computing capacity running complex logic and code at the network edge.
Get started with the CIS Edge Functions in the Standard and Enterprise plans.
Was this article helpful?
YesNo
More from Cloud
Attention new clients: exciting financial incentives for VMware Cloud Foundation on IBM Cloud
4 min read - New client specials: Get up to 50% off when you commit to a 1- or 3-year term contract on new VCF-as-a-Service offerings, plus an additional value of up to USD 200K in credits through 30 June 2025 when you migrate your VMware workloads to IBM Cloud®.1 Low starting prices: On-demand VCF-as-a-Service deployments begin under USD 200 per month.2 The IBM Cloud benefit: See the potential for a 201%3 return on investment (ROI) over 3 years with reduced downtime, cost and…
24 IBM offerings winning TrustRadius 2024 Top Rated Awards
2 min read - TrustRadius is a buyer intelligence platform for business technology. Comprehensive product information, in-depth customer insights and peer conversations enable buyers to make confident decisions. “Earning a Top Rated Award means the vendor has excellent customer satisfaction and proven credibility. It’s based entirely on reviews and customer sentiment,” said Becky Susko, TrustRadius, Marketing Program Manager of Awards. Top Rated Awards have to be earned: Gain 10+ new reviews in the past 12 months Earn a trScore of 7.5 or higher from…
IBM Tech Now: April 8, 2024
< 1 min read - ​Welcome IBM Tech Now, our video web series featuring the latest and greatest news and announcements in the world of technology. Make sure you subscribe to our YouTube channel to be notified every time a new IBM Tech Now video is published. IBM Tech Now: Episode 96 On this episode, we're covering the following topics: IBM Cloud Logs A collaboration with IBM watsonx.ai and Anaconda IBM offerings in the G2 Spring Reports Stay plugged in You can check out the…
IBM Newsletters
Overview Annual report Corporate social responsibility Inclusion@IBM Financing Investor Newsroom Security, privacy & trust Senior leadership Careers with IBM Website Blog Publications Automotive Banking Consumer Good Energy Government Healthcare Insurance Life Sciences Manufacturing Retail Telecommunications Travel Our strategic partners Find a partner Become a partner - Partner Plus Partner Plus log in IBM TechXChange Community LinkedIn X Instagram YouTube Subscription Center Participate in user experience research Podcasts United States — English Contact IBM Privacy Terms of use Accessibility
